PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting PDMS Design Error
  • Replies 7 replies
  • Views 5 views
PDMS Design Error
ANURAG AGARWAL
ANURAG AGARWAL over 18 years ago
  • ANURAG AGARWAL
    I am extracting the Isometric from PDMS Design Module.  Many times when I savework keeping Isometric open, the PDMS crashes out. Error is -
    .Filing error 26 in BRDIN, reading from token 65 - EOF: End of File
    Though this error is not consistent always but many times it is crashing.
    Please let me know how to resolve this error.
    Best Regards,
    Anurag
  • Peter Gulyas
    Peter Gulyas over 18 years ago
    I saw a note on aveva's support site that they corrected a crash about repeats of isodraftmode command. Try to upgrade to the latest fix release.
  • Praveen
    Praveen over 18 years ago
    We are working on Mutlti Write DB with extract claims and when working with MDS we are frequently facing the above Splash error and the PDMS will shutdown abruptly. Does anybody come across this type of problem and If you know any solution Please let me know.
    Thanks
    kp
  • Steve Crackett
    Steve Crackett over 18 years ago
    I had this error and it turned out to be a problem with the options file, not the switches in it. I recreated the options file from scratch with the same content and the problem was solved.
  • Peter Gulyas
    I think PDMS shouldn't crash because of ANY errors in the options file...
  • ram shankar prasad
    ram shankar prasad over 16 years ago
    Though my reply  may be very late, but it is worth 2 cents:), was getting the same error, if you change the option file  for previewing  in  design, you will get this error, solution to this lies in one attribute repeatbility..
    set it as off and that’s it
    Ram
  • David Simanek
    David Simanek over 10 years ago
    [QUOTE=ramshankar7;24904]Though my reply  may be very late, but it is worth 2 cents:), was getting the same error, if you change the option file  for previewing  in  design, you will get this error, solution to this lies in one attribute repeatbility..
    Ram
    I had a same problem, and this solution works! Thank you.
