I have a txt datal (db listing) file which is taken frm pdms 11.5 and while iam running it in 12 version i am getting a syntax error at certain line and tht is "version 1151". How to run this file in 12 version... with out error
I just output a spec in version 12.0SP4.4 and it includes the line "VERSION 1151". Are you running this in Specon or Paragon? Try running it in Paragon and in the command line type SPECONMODE.
If you are not in SPECONMODE you will get the error:
(47,15) CP: Syntax error
In line 6 of Macro C:\1j1.txt
^^VERSION 1151
I just tested it. So type SPECONMODE in the commandline and then try running in the macro.
