2D drawing doesn't appear correctly
  • Try changing the view to global or universal hidden line
    Rule references need to be looked at as well?
  • Have you read the manual for draft yet? It will guide you on the basic procedure for creating 2D drawings for instance: -
    Setting up views - limits, styles ect
    Setting rules - the way lines and shapes are represented
    Setting layers - how the hierarchy works
    These are fundamental issues that will take too long to explain in messages
  • Navigate to the VIEW and on the command line type Q RRSF.
    You should get something like Rrsf /DRA/PRJ/RERP/GEN/BASIC.....
    If you get RRSF NULREF....that's the problem
  • @ianmp; I've tried both global and universal hidden lines, they all produced the same thing i'm complaining about. How do i access the rule references?
    @amunir; please explain what you mean by "style of view"
    Thank you.
  • @ianmp; I've read the manual completely. I generated the drawing in the attached file myself. I just don.t know why the lines are appearing that way.
  • @corrado; Thank you very much. You're too much. You solved the problem. The problem is i was using /DRA/PRJ/RERP/GEN/PIPE.....,  so i just changed the pipe to basic.
    I appreciate.
    My next challenge is how to resize the view so i can have about three views in a sheet.
    Thanks once again.
  • I've found the solution to the problem of resizing views. It had to do with resetting the limits. Thanks a lot
