The drawing number in this UDA is our own drawing number on the clients drawing so it will be a different number to the drawing number
but thanks for the advice.
by the way do you know how or if there is a way for users to edit text from a 2d symbol item from the libary
eg I have a section arrow with the letter A in it , when the user inserts it I want them to be able to edit the text to change it to B
So is this by UDA oe PML or how you guys got another way of doing it??
Cheers
Wolfie
[QUOTE=Kubik;72929]what a hell.
I've tested this on my DRWG and there is no UDA!!!! The same problem :)
You should write a letter to your local support aveva office.
Hi Kubik,
See this last post
[COLOR=#333333]your problem is that the DRAWING on your screenshot is not a DRWG![/COLOR]
[COLOR=#333333]Your should DRWG but not a DRAWING which is other item in other hierrachy.[/COLOR]
[COLOR=#333333]I changed mine to DRWG and now it works well [/COLOR]
[COLOR=#008000]I am not sure if you have compiled it b4. Compilation is very important.
[/COLOR][QUOTE=Wolfie;72818]Hi
That worked
So question, how come i could not see that on drawing lvl ???? i had the lexicon set to drawing which I assumed was the drawing hierarchy
but I have changed it to sheet and it works , Have i used the wrong element for it to come out on the DRwg Level??
