One of the PDMS User is unable to see p-points highlighting while measuring the distance between Equipments / Structure …etc.., He is doing equipment modeling & positioning w.r.to available structural model.
After studying the problem, I understand the following things :
1. He has PDMS 12.1 SP2 and 12.0 SP4 Installed on his machine, In both version he can’t able to see P-points highlight.
2. Suppose If I consider it is a problem with Graphic card….But The same configuration graphic is installed on another machine from the same manufacturer, with same sttings too.....But he can able to see the P-points.
For your reference, The graphic card details are :
[COLOR="#0000FF"]---------------
Display Devices
Card name: ATI FireGL V3350
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x7153)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_7153&SUBSYS_1B021002&REV_00
Display Memory: 256.0 MB
Current Mode: 1152 x 864 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6635 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/8/2007 19:10:50, 260096 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 1/8/2007 19:10:34, 1724416 bytes
Device Identifier: {D7B71EE2-3213-11CF-596A-083BA1C2CB35}
Vendor ID: 0x1002
Device ID: 0x7153
SubSys ID: 0x1B021002
Revision ID: 0x0000
Revision ID: 0x0000[/COLOR]
I am still working on this issue…could you please suggest some idea to resolve this issue.
