PDMS "Lessons Learned"
Troubleshooting
[reports]How to add line number in pipe_mto.tmp ?
vipever
over 11 years ago
vipever
over 11 years ago
[reports]
build-in report template
C:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\reports\templates\pipe_mto.tmp
I want to edit the report template, and run report,
the first column has the line number,and quantity use subtotal
as follows
Serial
Type Detail Material Tube
Quantity
Text Text
1
ELBO ELBOW LR ANSI B16.9 BW ASTM A234-WPB 0.00
1
2
FLAN FLANGE WN ANSI B16.5 #300.RF ASTM A105 0.00
2
3
GASK GASKET RF 1.5MM ANSI B16.5 #300 SS & ASB 0.00
2
4
TUBI PIPE SCH40 ANSI B36.10 API5L GR.B 1796.95
2
5
VALV VALVE GLOBE ANSI B16.10 #300.RF ASTM A216-WCB 0.00
1
Ilgiz Kalimullin
over 11 years ago
it it impossible to add line number without pml programming
le martret
over 11 years ago
check report manual, but quantity is expressed base on subtotal
so you can easily add any additional infor in your report
