PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting Weld table on isometric
  • Replies 3 replies
  • Views 47 views
SHIVA SHANKAR
SHIVA SHANKAR over 11 years ago
  • SHIVA SHANKAR
  • sanjyot
    sanjyot over 11 years ago
    You need to modify option file...need to switch on Weld Table option in Weld Numbering tab, select which columns you need for the table...Then give the position for the weld table....
  • Nguyen Hong Anh
    Nguyen Hong Anh over 8 years ago
    it shall work if you choose source is generated but you cannot modify weld table. So if i choose source from Db, i can setup the properties for weld table but nothing happen. Can you tell me how to setup if i choose source from db?
