PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Troubleshooting no more command
  • Replies 7 replies
  • Views 23 views
no more command
adak
adak over 6 years ago
  • adak
    hi
    on pdms 12.1, no more command are available : i get always "syntax error".
    before, i do $s- $s+ and all command back but not this time.
    how to unlock pdms ?
    thanks
  • Matts Nordman
    Matts Nordman over 6 years ago
    You can always run the command ”$q” in any situation, that will list any command that you can run. Probably you have to issue an ”exit” or two in case a form has crashed. ”Finish” nearly always works too, that will shut down PDMS so you can start over.
  • adak
    here the result of $q
    $q
    )              Sfeet (space{+/-}digits')     Xfeet ({+/-}digits')
    Sdigit (space{+/-}digits)     Xdigit ({+/-}digits)
    Sfract (space{+/-}digits/digits)             Xfract ({+/-}digits/digits)
    Spoint (space .)              Xpoint (.)     +.             -.             (
    Newline
    i can't run any command even "finish" or "exit" : i got always "syntax error"
    other idea
    anyway thanks for help
  • Matts Nordman
    It looks like you could just type a closing bracket, ")", to get to a more normal state. Do you know what you did when this happened? Did you run a macro? Open a form? Something else?
  • adak
    i was input weight for bolt (bweight in dtab), and i try a copy/paste from my excel sheet witch contains my weight value
  • adak
    hi mno
    that's right : in my copy/paste i forgot the last )
    thanks
  • Matts Nordman
    You can't copy & paste data from an excel sheet, but you still shouldn't get the messages you are getting. Weird, but the reason is that you are pasting data from Excel.
