OPTIONS DEFAULT AppWareText 'COMMENT1' unset AppWareText 'COMMENT2' unset AppWareText 'COMMENT3' unset AppWareText 'COMMENT4' unset AppWareText 'COMMENT5' unset AppWareText 'COMMENT6' unset AppWareText 'COMMENT7' unset AppWareText 'COMMENT8' unset AppWareText 'COMMENT9' unset AppWareText 'COMMENT10' unset AppWareText 'RENAME' 'ON' MM Bore MM Distance Precision Bores NOMINAL CuttingList OFF Cutmarks OFF Charheight 2mm HYPERPLANT OFF Date EUR Dimdistance String 11mm Dimdistance Overall 16mm Dimdistance Supports 6mm Dimensions ON Dimensions Composite OFF Dimensions Overall OFF Dimensions Hangers OPPOSITE strings Supports STRING Margin LEFT 20mm Margin RIGHT 10mm Margin TOP 10mm Margin BOTTOM 10mm Size A2 FlowArrows OFF FlowArrows Inline Scale 8 Frame ON Reserve 20mm Reserve MaterialList 83mm FallingLines PERCENTAGE 9 AccuracyLevel 1 AngleAccuracy 0 LooseFlangeAllowance 150mm Isotype COMBINED File DXF /C:\AVEVA\845-ISO\ SINGLE Units METRIC Mark Detail OFF Mark Revision OFF Mark Ignore ON PlottingScale 100 PictureScale 100 Stacking 2 ALONG Split 100 PERCENT SpoolNumbers OFF ISO 2 Box Wastage AREA 1 1 Wastage AREA 2 1 Wastage AREA 3 1 Wastage AREA 4 1 Wastage AREA 5 1 Wastage AREA 6 1 Wastage AREA 7 1 Wastage AREA 8 1 Wastage AREA 9 1 Weldnumbers OFF Weldid OFF Weldtype ON Underlayplot /%SNMISO%/UND/845-ISO_A2.plt 1 SymbolFile Off MessageFile /mess OVERWRITE TransferFile OFF CllengthFile OFF CutpipelistFile OFF SupportFile OFF MatlistFile OFF MatControl OFF MaterialList ON MaterialList DRWG MaterialList RIGHT DESCRIPTION MaterialList Charheight 2.45mm Lspacing 125 MaterialList Code 7 DUMMY SUFFIX SINGLE MaterialList PartNumbers GENERATED MaterialList TableDefinition Column 1 PARTNUMBER with Width 3 Column 2 DESCRIPTION with Width 50 Column 3 BORE with Width 8 Column 4 ITEMCODE with Width 10 Column 5 QUANTITY in Millimetres with Width 9 CompipeFile OFF Compipe MTO DRWG Compipe Itemcodes USER Compipe Descriptions SHORT Compipe Supports ON Atext 251 '' Atext 252 '' Atext 253 '' Atext 254 '' Atext 255 '' Atext 256 '' Atext 257 '' Atext 258 '' Atext 259 '' Atext 260 '' Atext 261 '' Atext 262 '' Atext 263 '' Atext 264 '' Atext 265 '' Atext 266 '' Atext 267 '' Atext 268 '' Atext 269 '' Atext 270 '' Atext 271 '' Atext 272 '' Atext 300 '' Atext 301 'PT' Atext 302 'NO' Atext 303 'DESIGNA��O' Atext 304 'DN' Atext 305 'C�DIGO' Atext 306 'QTD' Atext 307 'TUBAGEM' Atext 308 'ACESS�RIOS' Atext 310 '' Atext 311 'JUNTAS' Atext 312 'PERNOS E PORCAS' Atext 313 'V�LVULAS' Atext 314 'INSTRUMENTA��O' Atext 315 'SUPORTES' Atext 316 '' Atext 317 '' Atext 318 '' Atext 331 'mm' Atext 332 'P�GINA' Atext 343 'CONTINUA' Atext 400 '' Atext 401 '' Atext 402 '' Atext 403 '' Atext 404 '' Atext 405 '' Atext 406 '' Atext 407 '' Atext 408 '' Atext 409 '' Atext 410 '' Atext 411 '' Atext 412 '' Atext 413 '' Atext 470 '' Atext 471 '' Atext 472 '' Atext 473 '' Atext 474 '' Atext 475 '' Atext 476 '' Atext 480 '' Atext 481 '' Tagging ON Instname NAME with balloon size 5 Delimiter COLON InsulationControl ON TracingControl ON Attaname SPREF Tolerance Offset 1mm Tolerance Angle 0.06 Specbreak COMPONENT SpecChanges OFF Axes WORL /* ContinuationSymbols OFF Itemcode Valves DEFAULT Itemcode Instruments DEFAULT Itemcode Pcoms DEFAULT Itemcode Traps DEFAULT Itemcode Vents DEFAULT Itemcode Filters DEFAULT Itemcode SEPARATE Itemcode from SPREF Bolting length description ON Bolting length itemcode APPEND Bolting Units METRIC Coords OFF AT Pipe Coords OFF AT Nozz Coords OFF AT Open Coords OFF AT Clos Coords OFF AT Vent Coords OFF AT Dran Coords OFF AT Misc Elevation INTERSECTION Skewbox TRIANGLE NSTD Standout 4mm Hatch 3mm Partial 20mm Tags OFF Zerolengthskews ON Fallskews THREEDBOX ON TextPosition NAME X 467mm Y 17mm CharHeight 2mm TextPosition '1) As dimens�es das linhas em tro�os com di�metro igual ou inferior a DN50,' X 160mm Y 20mm CharHeight 1.9mm TextPosition ' s�o aproximadas e ter�o de ser confirmadas em obra pelo empreiteiro.' X 281mm Y 20mm CharHeight 1.9mm TextPosition '2) Os suportes das linhas com di�metro igual ou inferior a DN50, ser�o' X 160mm Y 15mm CharHeight 1.9mm TextPosition ' definidos em obra pelo empreiteiro e submetidos � aprova��o da fiscaliza��o.' X 274mm Y 15mm CharHeight 1.9mm TextPosition 'REDE DE COMBATE A INC�NDIOS' X 447mm Y 35mm CharHeight 2.5mm TextPosition 'ISOM�TRICA' X 465mm Y 26mm CharHeight 2mm TextPosition 'LINHA:' X 455mm Y 17mm CharHeight 2mm TextPosition 'PARA COMENT�RIOS' X 418mm Y 69mm CharHeight 2mm TextPosition 'REVIS�O GERAL' X 418mm Y 74mm CharHeight 2mm TextPosition 'A' X 408mm Y 74mm CharHeight 2mm TextPosition '845' X 535mm Y 19mm CharHeight 4.5mm TextPosition 'XXXXX' X 551mm Y 19mm CharHeight 4.5mm TextPosition 'A' X 577mm Y 20mm CharHeight 4mm TextPosition DATE X 524mm Y 74mm CharHeight 1.7mm TextPosition '04/03/2009' X 524mm Y 69mm CharHeight 1.7mm TextPosition '04/03/2009' X 436mm Y 56mm CharHeight 2mm TextPosition '04/03/2009' X 436mm Y 51mm CharHeight 2mm TextPosition '04/03/2009' X 436mm Y 46mm CharHeight 2mm TextPosition '04/03/2009' X 436mm Y 41mm CharHeight 2mm TextPosition 'RMP' X 423mm Y 56mm CharHeight 2mm TextPosition 'MAR' X 423mm Y 51mm CharHeight 2mm TextPosition 'RMP' X 423mm Y 46mm CharHeight 2mm TextPosition 'JGL' X 423mm Y 41mm CharHeight 2mm TextPosition 'MAR' X 544mm Y 69mm CharHeight 2mm TextPosition 'RMP' X 559mm Y 69mm CharHeight 2mm TextPosition 'JGL' X 574mm Y 69mm CharHeight 2mm TextPosition 'MAR' X 544mm Y 74mm CharHeight 2mm TextPosition 'RMP' X 559mm Y 74mm CharHeight 2mm TextPosition 'JGL' X 574mm Y 74mm CharHeight 2mm TextPosition 'FOLHA' X 552mm Y 26mm CharHeight 2mm TextPosition SHEETN X 562mm Y 26mm CharHeight 2mm TextPosition ' /' X 563mm Y 26mm CharHeight 2mm TextPosition SHEETT X 567mm Y 26mm CharHeight 2mm Bendradius DISTANCE Itemcode Length LONG Tapping Scale 100 Tapping Dimensions ON Tapping Coordinates OFF Truncate OFF EquipmentNumbering NOZZLE Outcom OFF Tubesplits ON Repeatability OFF Mtexts ON Mtexts XTEXT Dtexts ON Dtexts RTEXT Leglength 9mm Overallskews ON Refdimensions ON BoltFile OFF WeldTableFile OFF BendTableFile OFF ContNotes BOTH Descriptions OFF ContSheets ON ContWelds OFF ContJoints OFF JointNumbers OFF PBendNumbers ON Logical TRUE 'TRUE' FALSE 'FALSE' ShortCode ' OFF' PipenameDelimiter Prefix OFF PipenameDelimiter Suffix OFF LineThickness 4 MessageAccuracy RADIAL 1 MessageAccuracy ITERATIONS 1 Cutback none Attexts none Change Highlighting OFF Change Highlighting Colour 2 Change Highlighting Rule Unset $.
