Pessoal,
Alguém sabe como identificar qual usuário fez uma determinada ação no PDMS 12.0?
Exemplo, quem fez uma alteração em um elemento modelado?
abs,
there are differences and changes options inside this form and you can choose which session go from. It will tell you everything that happened since the session selected til present on the element you select.
But it's not well set out it won't tell you when and what users for each change. It probably could... but it doesn't :(
I am thinking it should be possible to array the history, user and time of sessions on a particluar element or set of elements.
Then it might be possible to find out what happened in each session to each item. By going back session by session from present day back to a target date and capturing the array details for each time that is a change on the particular element.
