• Hola con tod@s
    Alguien sabe si existe algun comando para hacer un unhide (visualizar solamente los objetos seleccionados o en su defecto los no seleccionados en transparencia)??
    Saludos y gracias por adelantadooo.
    Cristhian
  • En PDMS no puedes hacer selección múltiple como en otros programas, siempre tendrás un único CE activo así que el problema que tienes tendrías que enfocarlo de otra manera.
    Saludos,
  • Teenwolf ubique lo siguiente en la red:
    Interesting Trick – Drawlist to Translucent…
    22
    MAY
    I had a need for something interesting, so I thought I would Share…
    I needed to take everything on my screen in the graphical display (3D view), and convert it to translucent (except for my current Element). I have not seen a convention in the application for doing this, and since I am working with a specific volume, doing this through the hierarchy is not effective.
    So, here is how I accomplished it:
    – Store CE
    !CE = !!ce.name
    – Capture Drawlist Contents
    var !!MyDrawlist EVAL Name for all from Drawlist
    – Remove everything, and add the contents back in translucent
    rem all
    AutoColour off
    add all from !!MyDrawlist col Brown transl 50 edges on
    AutoColour on
    – Now, re-add CE using AutoColour
    rem $!CE
    add $!CE
    For what I was doing, this worked great… I’m sure it could be adapted for other purposes…
    for those who do not like to write a macro. This also can be achieved using a LIST
    !ce = !!CE
    Start a LIST and select all from DRAWLIST
    REM ALL
    AUTOCOL OFF
    In the Action line of the list type:
    ADD CE COL BROWN TRANSL 60 EDGES ON
    and run it.
    AUTOCOL ON
    REM $!ce
    ADD $!ce
    Good Success!
    Aunque no se como aplicarlo .. me das una mano con ello ??
    (  la pagina de referencia es: http://pdmsmacro.wordpress.com/  )
    Saludos
