Dependency Walker
Anonymous
Anonymous
Version
2.1
Requirements
Windows 95, 98, Me, NT, 2000, and XP
Description
Dependency Walker is a free utility that scans any 32-bit or 64-bit Windows module (exe, dll, ocx, sys, etc.) and builds a hierarchical tree diagram of all dependent modules. For each module found, it lists all the functions that are exported by that module, and which of those functions are actually being called by other modules. Another view displays the minimum set of required files, along with detailed information about each file including a full path to the file, base address, version numbers, machine type, debug information, and more.
Dependency Walker is also very useful for troubleshooting system errors related to loading and executing modules. Dependency Walker detects many common application problems such as missing modules, invalid modules, import/export mismatches, circular dependency errors, mismatched machine types of modules, and module initialization failures.
Updates can be found on http://www.dependencywalker.com
Author
Steve P. Miller
Submitter
Eric Black This email address is being protected from spam bots, you need Javascript enabled to view it
