Description This control was designed to work with Citect for systems that use recipes in the manufacturing process. Features include:
Recipes can be stored in any database that is running on Microsoft Windows. Display recipe data in grid view. Recipes can be downloaded to Citect tags Add/Edit/Delete recipes. Easy to use and no coding required.
Limitations: The current version of CiRecipe.ocx supports up to 30 columns that allow you to bind them with your Citect tags. We consider expanding the number of binding columns in the next version.
Required Components:
MDAC2.5 or above Citect V5.30 or above. Note: It is possible to work with Citect V5.21, but you have to do some Cicode coding to interface with the control. This control is not tested with Citect v5.21.
Please Note: Read the readme.txt for more information on Installation Notes.
