Requirements Tested on Microsoft Windows XP and Windows 2000
Description NEW IN V1.1.0: _____________________________________ This latest version of this utility adds the option to add a 'X' Close button to the top right of the screen, whilst still maintaining full-screen view without toolbars / titlebars.
This Close button Kills all MSHTA processes, working around a known MS issue where allthough a HTA appears to be closed, the MSHTA process continues (in the case of WebClient, the licence remains in use). _____________________________________
This program will create an HTA file (HTML for Applications) which will enable you to customise the view of WebClient, in ways not available in Internet Explorer.
You can choose to run Webclient as true fullscreen, with no titlebar, no scrollbar, and even hide from the taskbar, amongst other things.
Once created, simply double click the file or a shortcut to the file when you wish to open the webclient (no need to remember the URL).
The program can even create batch files that will assist in setting up WebClient to run as a Microsoft Windows shell replacement.
This program adds security by not having any URL address bar, so when running as a shell, there is no access to other websites or local files.
