Description CsiCitectInfo() is an enhanced version of the standard CitectInfo() function. It can return any project information that is stored in the project's PROJECT.CIT file, such as name, description, major / minor revision number, creation date / time, default page properties, project ID, etc. Include this CiCode file in your project and call CsiCitectInfo("project",sProjectName,sInfoType). All parameters are documented in the source file.
If you are running a project in multiple areas or sites (each with multiple included projects) this is a very good basis for a version control aid. It allows the revision of each project to be displayed on screen (without having to exit to the explorer to get the version info).
