There are significant changes required for this to work in VB.Net - These have been made and uploaded to the Toolbox as: Q1331 http://knowledgebase.citect.com/toolbox/article.aspx?id=1331
Can you please add the solution and the project of your examples?
I get in C# Visual Studio 2010 (same with 2008) the following exception :
{"Unable to load DLL CtApi.dll: The specified module could not be found. (Exception from HRESULT: 0x8007007E)"}
I can not add it as a reference, I can not use regsvr32.
It seems to be the same problem with Q1331. I am also unable to load the dll.
Can you please tell me how you did?
Thanks in advance.
Pierre Major/Cristian Badescu
