RegEx Search And Replace
Anonymous
Anonymous
Provides Powerful Text Search and Replace Functionality Using Regular Expressions
Version
v1.1.3
Requirements
n/a
Description
This tool uses the Microsoft VB Scripting RegEx control to allow searching and optionally replacing text using regular expressions. It includes a handy syntax guide. Regular expressions allow searching for patterns instead of just specific text--allowing for much more advanced searching than most text editors allow. See http://en.wikipedia.org/wiki/Regular_expressions and http://www.regular-expressions.info for more details.
Updates
1.1.3 Fixed Find button selecting text before the first match
Fixed negative column numbers
1.1.2 Fixed out of bounds error when replacing text in long documents
Fixed underscored link on help page
1.1.1Fixed horizontal scrollbar getting cut off for Regular Expression Syntax
Added prompt to save before closing
Added Find Previous button
Added Edit menu with clipboard actions and Select All feature.
Added help page
1.1.0Removed 64K limit on search text length.
Added file open/save actions. Increased font sizes.
Find text now shows previous 20 searches in a dropdown list.
Ctrl-A can now be used to select all text in any textbox.
Fixed problem with match count getting cut off for large numbers of matches.
Added line, column, and search text length counters.
A file or text can now be displayed by dragging it from another application and dropping it on the search text box.
The syntax text can be hidden to reduce the window size.
Settings are now saved in an INI file (default) or in the registry (Options menu).
Author
Eric Black
Submitter
Eric Black
