Easy RoboCopy
Anonymous
Anonymous
Graphical User Interface for RoboCopy Utility
Version
1.0.15
Requirements
Windows 7 / 2008 Server and above
Description
RoboCopy.exe is a Microsoft command-line tool for copying files and folders. It is very fast, fault-tolerant, and has dozens of parameters to customize the copy process, such as filtering by name, attributes, synchronizing folders, etc. Easy RoboCopy is a graphical user interface for RoboCopy. It shows all available arguments on one form with descriptive names and tooltip help. Any arguments that require a specific OS/Robocopy version are color-coded in the interface. As options are selected, the corresponding command line is shown and may be executed directly or saved to a batch file.
Robocopy.exe is built in to modern Windows releases. For XP and 2003 server, you need to download robocopy.exe and put it in c:\Windows\System32 manually.
Updates
1.0.17
Fixed problem with Copy to Clipboard not working
1.0.16
Added Copy to Clipboard button. Added freeware license
1.0.15
Fixed problems saving/loading INI settings with double quotes
1.0.14 Added Windows 10 RoboCopy arguments. Removed robocopy.exe from the installer since it's included with Windows 7, Server 2008 and above.
Author
Eric Black
Submitter
Eric Black
