MOSCAD CFG Creator
Anonymous
Anonymous
Create MOSCAD CFG files based on your DBF files
Version
1.0
Requirements
Microsoft Excel, MOSCAD Toolbox and CitectSCADA
Description
This macro, when run, allows you to specify your Variable and Units .dbf file locations then it will extract the required data from the .dbf files and create the MOSCAD configuration file, based on your system specifics. This is ideal for projects with lot of units defined, saving the engineer time in creating the configuration file manually.
Author
Johnny Wapstra
Submitter
Serhas Ogutucu
