SnippetKeeper
Anonymous
Anonymous
Toolbox Template
Source Code Database
Version
1.0.3
Requirements
Windows 2000 or later
Description
SnippetKeeper is designed to be a personal source code and tip library for multiple programming languages. It organizes your items by programming language and category (both user-defined), and allows items to belong to multiple categories. All items and file attachments (compressed to save space) are stored in a single SQLite database file and it can be exported to/imported from a tab-delimited text file. Go to the Help menu and choose About for complete documentation.
A sample database containing hundreds of tips and sample functions for VB6, Cicode (many from the Toolbox), C++, VB.Net, and more is available as a separate download.
Visual Basic 6 source code for SnippetKeeper as well as the Visual C++ 2008 Express project for the SQLite database DLL is available as a separate download.
"SnippetKeeper vx.x.x Setup.exe" is the only file required to install SnippetKeeper.
Updates
v1.0.3 Added error message if backup fails. Changed 'Last Update' sort to descending order. Last Update datestamp is now updated when re-saving item
v1.0.2 Removed automatic proportional resizing of Language and Titles panes. Moved settings to INI/Registry. Fixed error on exit when no database was open. Added ability to drag attachment to Windows Explorer
v1.0.1 beta Fixed crash when last database path no longer exists. Added ability to browse to select backup file on exit
v1.0.0 beta Original release
Author
Eric Black
Submitter
Eric Black
