Trend Path Modifier
Anonymous
Anonymous
Modifies trend files to point to a different path
Version
1.00.000b
Requirements
CitectSCADA V5.00 - V5.30
Description
In CitectSCADA V5.00 - V5.30, trends can only be moved to a different folder in specific cases (see Citect Knowledge Base article Q2143) because the file paths are stored in the HST file for each trend tag.
Install and run this utility to modify the paths on all the HST files in a selected folder. After that, the trend files may be moved. Click the help button for details.
Source code is included.
This utility is no longer necessary in Citect 5.31 and later. Citect will automatically update the HST files if the paths are changed in the trend tags database.
Author
Eric Black
Submitter
Eric Black
