Environment Manager - v2.16
Anonymous
Anonymous
The previous CitectSCADA tool Environment Manager has been updated and made available via the Toolbox. It has been updated to support up to Citect SCADA 2016 (v8.0)
Features:
    · Support for multiple versions within a release – This allows you to change Service Packs
    · Support for ClearSCADA files (v7.30 onwards)
    · Support for Web Client – Server files
    · Introduces a “global” store so users can share captures
    · Introduces a custom store for updates AFTER the copy – e.g. restore a particular driver version
    · Update the “IO to Disk” to be “IO to Persist” – memory mode with persistence on
    · “ecf” archives can be restored to the local or global location
    · Command line support of specific version to make active, e.g. -makeactive=7.50.000.4107
Please see the attached PDF document for more details on v2.16
Environment Manager should NOT be used on a live system, it is an engineering tool. It is strongly recommended that projects be backed up before use.
Please also be aware that Environment Manager tool is not considered to be a supported tool and it is currently not being maintained. SCADA Support recommends to use virtual machines instead to manage multiple versions of SCADA on the machine as this ensures each version installation is clean and supportable.
In case of any clarification, please feel free to contact SCADA Global Support.
