Hi
We are working on an AVEVA migration project which requires unattended installation of the applications. However it fails as Manual says:
execute the following at the command line using the System Centre Configuration Manager
eg "msiexec /i "file location"\setup.msi /quiet INSTALLLEVEL=6" But there is no such file named setup,msi, instead setup.exe.
We are doing via powershell. Is there any solution you can suggest please?
Thanks in advance.
