1.  How likely is it that you will know (or be given) every PI Point name you need to work with?
Very difficult, the information is unstructured, we need to hope that the naming conventions are meaningful but very often they are not
2.  Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
Using the feature Swap Asset in the Asset Framework
3.  Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
Searching for the Pi Point and modify the display
