1. How likely is it that you will know (or be given) every PI Point name you need to work with?
Not very likely. However, if I could have memorized many of them from having to search for them in limited tools, or if current monitoring displays show raw tag names.
2. Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
Make sure MixingTank1 is built within the Asset Framework, and then swap over the display to MixingTanks2.
3. Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
Manually remove the old products and manually add the new ones.
