- How likely is it that you will know (or be given) every PI Point name you need to work with?
  1. How likely is it that you will know (or be given) every PI Point name you need to work with?
  • Not likely at all
2.    Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
  • If you used asset framework you simply select MixingTank2
3.    Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
  • Assuming you used asset framework, it will update automatically.
