1. How likely is it that you will know (or be given) every PI Point name you need to work with?
A: By hierarchy Asset Framwork
2. Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
A: Using asset framework as the backbone
3. Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
A: Looking by tag by his name
