1. How likely is it that you will know (or be given) every PI Point name you need to work with?
- Very likely
2. Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
- Since the asset framework is used as the backbone, the values will be automatically updated when I choose MixingTank2 from the drop down menu.
3. Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
- Since we don't need to change the parameters of the products (temp, pressure, etc), we can just ignore the product change and focus on the values of the parameters of the changed products.
