Questions from the Course:
How likely is it that you will know (or be given) every PI Point name you need to work with? Ans - It will be present in the AF.
Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
Ans - We don't need to build another display rather just toggle between the different Assets. And hence we would switch to MixingTank2 from the Asset dropdown.
Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without use of Asset Framework?
Ans - I am not sure about this one. Please share your answer.
