1.    How likely is it that you will know (or be given) every PI Point name you need to work with?
  • If I wish to know every PI Point I should know the format of the tags to be created, but PI AF is more friendly with users, so they don't need to know what point it comes from.
2.    Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
  • If I have MixingTanks in a hierarchy in PI AF, the only thing I have to do is to change in PI VISION display, the asset from MixingTank1 to MixingTank2.
3.    Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
  • If the display is created base on PI Points, what I must do is to change manually every element of the display.
