AF Attributes vs. PI Points
  1. It's not likely to know every given PI Point, but if PI points are created using structured naming convetions, you can identify the process unit, area and function.
  2. Using AF allows you tu use same displays obejects for different class members (tanks, pumps, reactors, etc).
  3. PI points can be rearranged manually to be used for differenct products on same equipments (without using AF).
