Hey, I am a beginner, I am trying to use it to help estimate and record MTBF, MTTF ... etc. the idea that I have is to build a calculated tag that is linked to the circuit breaker or equipment speed, and the output of that is either 1 or 0. then if the equipment is standby status I would change from 0 to 1. as result, we will be able to estimate the availability and reliability of any given equipment.
is this the easiest, fastest, and most reliable way? or there is a better solution.
regards
