Does anyone to simulate gas-liquid absorption in SimCentral?. I would like to perform SO2 absorption in water (or any other liquid) in SimCentral 4.0. I defined SRC1 as water and SRC2 as gas mixture (N2, O2, SO2) and connected to column model. However, model message is “Streams with different fluid types should be to the same port not connected”. Should I use splitter and connect only one stream to the column?
