How to create alerts in PRO II
Hi all,
In a fractionation column, I am trying to do simulation of column at low reflux ratio than design. During this exercise it was found that the reflux flow to column was going much less than Reflux pump minimum flow.
To compare pump minimum flow and reflux flow of column, I have to run simulation, generate results & compare them manually.
Is there any other way by which I can compare this two flows & can I generate some sort of Message Box Or error so that the manual intervention for comparing flows can be stopped.
Please anyone suggest.
  • You could use a calculator to do the comparison. The the result from the calculator could be a numerical value that you could visually see was above or below the threshold you set. For instance the result could be 0 for below and 1 for above. If you have further questions, please email support.simsci@schneider-electric.com for assistance.
