You should check on the tutorial and manuals that come with your PDMS installation. The structural module manual has step by step examples and should be enough to get started.
HOW CAN I IMPORT A FILE WITH IGS OR STEP FORMAT TO PDMS?
thans
a.
There's a new Mechanical Equipment Interface for PDMS 12.0.SP5 onwards - it can read a STEP file directly into PDMS, where it's stored in a new primitive.
Yes,maxon is right. If you want to add gridline,you have to go to utilities-reference data and then Reference Definition Application form will come out. In there, you go to creat-gridline-area where to bulid your grid line. And then if you want to tag on gridline, you go to Graphic-Tag Gridline. Cheers!
[QUOTE=max0n;27107]what do you want to know about gridlines?
