If I'm not wrong, in this way when you send the dwg to other computer all the texts come out of place.
As far as I know there's no way to perform this matter.
If you need to load other fonts in PDMS for using with draft ( not Isodraft) you need to load the fonts using the admin module, so the true type fonts can be used by draft module.
when i go through that link which u have sent i come to know that autocad fonts we cant use directly is it so, if is it so i have to use converter right?...
