PDMS to CAESAR-II - Verified Accuracy
  • I have already checked PSI license, it's valid..
  • Data consistency is fine, no error.. But when i want to convert to cii file still error., :(
  • Could you please post an image of the command line once you get the error?
    Maybe you can type $r6 just before selecting "write data to file"....
    Do you have the correct folders structure?
    I mean, main project folder XXXPSI and 4 subfolder INPUT, OUTPUT, RETURN and LOG?
  • By the way........I had a similar issue with an italian customer now that I remember....
    PSI doesn’t like when the XXXPSI variable  is set to a path that contains \\servername\XXX\XXXPSI notation.
    If you map a drive like Q:\XXX\XXXPSI it should work fine.
          endif
          !lines.append(|<InsulationThickness>$!this.insulationthickness</InsulationThickness>|)
          !lines.append(|<Position>$!this.position.east $!this.position.north $!this.position.up</Position>|)
          !lines.append(|<BendRadius>$!this.bendradius</BendRadius>|)
          if !this.componentType inset('ELBO','BEND') then
          endif
          !lines.append(|<SIF>$!this.sif</SIF>|)
          if !this.restlines.size().gt(0) then
          endif
          !lines.append(|</Node>|)
          return !lines
          if !a.componentType.eq('BRAN').and(!a.point.eq(2))  then
          endif
       enddo
          if !a.componentType.eq('BRAN').and(!a.point.eq(1)) then
          endif
          !lines.appendarray(!a.makenodelines())
    define method .makenodelines()is ARRAY
          !lines = ARRAY()
          if !this.componentType.eq('BRAN') and !this.point.eq(1) then
          endif
          !lines.append(|<Node>|)
          if !this.nodenumber.unset() then
             !num = -1
          else
          !lines.append(|<NodeNumber>$!num</NodeNumber>|)
          !lines.append(|<Endpoint>$!this.point</Endpoint>|)
         if !this.rigid.eq('END') then
         else
            if !this.rigid.eq('START')  then
            endif
            !lines.append(|<ComponentType>$!this.componentType</ComponentType>|)
              if !this.weight.unset() then
              endif
              !lines.append(|<Weight>$!this.weight</Weight>|)
         endif
          !lines.append(|<ComponentRefNo>$!this.component</ComponentRefNo>|)
          !lines.append(|<OutsideDiameter>$!this.outsideDiameter</OutsideDiameter>|)
          !lines.append(|<WallThickness>$!this.wallThickness</WallThickness>|)
          !lines.append(|<CorrosionAllowance>$!this.corrosionAllowance</CorrosionAllowance>|)
          if !this.AlphaAngle.set() then
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
          else
             !num = !this.nodenumber
          endif
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
             !lines.append(|<BendType>$!this.bendtype</BendType>|)
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
          else
          endif
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
          else
          endif
         else
              !lines.append(|<Rigid>1</Rigid>|)
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
             !num = -1
          else
         else
            endif
              endif
         endif
          endif
          endif
          endif
          return !lines
          endif
       enddo
          endif
          !lines = ARRAY()
          endif
          else
          endif
              !lines.append(|<Rigid>2</Rigid>|)
              !lines.append(|<ComponentType>RIGID</ComponentType>|)
              if !this.rigidweight.unset() then
               endif
              !lines.append(|<Weight>$!this.rigidweight</Weight>|)
         else
          endif
          endif
          endif
          return !lines
             !lines.append(|</Branch>|)
          endif
       enddo
       !this.lines = !lines
       !this.endreport()
    define method .endreport()
      !lines = !this.lines
      !lines.append(|</Pipe>|)
      !lines.append(|</PipeStressExport>|)
    endmethod
    endmethod
      !stressGroup = !this.currentGroup.stressgroupname.after('/')
      !fileName =  '$!psidir' & '\' & 'output' & '\' & !stressGroup & '.xml'
      !outputFileName = object FILE('$!fileName')
      !this.currentGroup.writedata(!outputFileName)
    define method .writeData(!file is FILE)
      !file.writefile('Write',!this.lines)
      handle ANY
      handle ANY
         !!alert.error('Write Aborted')
      endhandle
    endmethod
      !formDirName = object FILE(!!pml.getPathName('psisystem.pmlfrm'))
      !formLoc = !formDirName.directory()
      !coreLoc = '$!formLoc' + '\..\..\..\core'
      syscom '$!coreLoc\convert_to_cii.bat $!psiDir $!stressGroup $!coreLoc'
    endmethod
    $r
  • Do you have the correct folders structure?
  • yes, i have.. i've copied from sam project and changed the name with XXXPSI..
  • i've tried, tried, and tried again.. and now, it's work... yeahh,, :D
    very very thank you for corrado d(^^,)
  • It would be interesting knowing the way you've solved it...
  • i try to convert in new stress group, and it's work.. :D
