General
General
Show Off Your Work! Model Data Exchange Addin
  • Replies 38 replies
  • Views 54 views
eryar
eryar over 11 years ago
  • Dmitry
    Dmitry over 11 years ago
    Does not work in version 12.0.SP6.39.
  • Dmitry
    Yes. Start PDMS from the folder "Model Data Exchange folder. All fulfilled in accordance with Your instructions. Button "ModelExport" visible on the toolbar. When I press occurs described exception. Assembly DataExchangeWrapper not registered. I use PDMS version 12.0.SP6.40. In this configuration uses .NET Framework 3.5 (see http://support.aveva.com/support/United_Kingdom/ ). More before version PDMS use the .NET Framework 2.0. Could that be the problem? In what Framework is assembled Your library DataExchangeWrapper?
  • Pradeep Shetty
    Pradeep Shetty over 11 years ago
    Received same exception error on 12.0.SP6.46
    Tried both using the run.bat & standard pdms.bat after adding the path etc. Same exception error in both cases.
  • eryar
    The button "ModelExport" visible on the toolbar means the .Net Addin is loaded successfully. The DataExchangeWrapper.dll has problem. I tested the addin both in WinXP 32bit and Win7 64bit. What's your computer configuration information?
  • eryar
    Is your computer OS is Win7 64bit? [QUOTE=Sps;80015]Received same exception error on 12.0.SP6.46
  • Dmitry
    The configuration of my PC: WINXP x32, PDMS 12.0.SP6.40
  • me_hungry
    me_hungry over 11 years ago
    Hi eryar[COLOR=#3E3E3E] ![/COLOR]
    Is it possible to copy only this Dll`s:
    ModelDataExchangeAddin.dll
    to aveva root and add to designaddin name of your assembly for proper ?
    Also appering FileNotFoundException(HRESULT: 0x8007007)
  • eryar
    The run.bat already do this for you. And also need set the environment variable %PATH% for bin folder. [QUOTE=me_hungry;80031]Hi eryar[COLOR=#3e3e3e] ![/COLOR]
  • eryar
    I will test it with the same configuration.
  • me_hungry
    Aaah.I dind`t  set variable to folder with bins...
    Is it possible to combine all assemblies in one .dll ?
