General
General
Show Off Your Work! Model Data Exchange Addin
  • Replies 38 replies
  • Views 73 views
eryar
eryar over 11 years ago
  • me_hungry
    me_hungry over 11 years ago
    It is hard to manage such amount of assemblies...Or U do it for protection?
  • eryar
    Must set the %PATH% environment variable for bin folder. I use some open source libraries, so I would not combine them... Set the environment for bin is easy...  :-)[QUOTE=me_hungry;80045]Aaah.I dind`t  set variable to folder with bins...
    Is it possible to combine all assemblies in one .dll ?
  • eryar
    Config the Run.bat according to your AVEVA Product root directory, then start the PDMS by Run.bat. And then the ModelDataExchange folder can be anywhere.
  • eryar
    Hi, Piligrim34:
    I tested the Addin on my WinXP 32 PDMS 12.0, It works.
    Make sure the bin folder of ModelDataExchange set to the %PATH% environment variable.
    The configuration of my PC: WINXP x32, PDMS 12.0.SP6.40
  • eryar
    Hi, Sps:
    Make sure the bin folder of ModelDataExchange set to environment variable.
    If the .Net addin loaded successfully and the bin set to environment variable,
    the addin will work.
    [QUOTE=Sps;80015]Received same exception error on 12.0.SP6.46
    Tried both using the run.bat & standard pdms.bat after adding the path etc. Same exception error in both cases.
  • Pradeep Shetty
    Pradeep Shetty over 11 years ago
    Hi, my workstation is Windows 7 64bit. I did add bin folder to the %path% variable too...
    I will try on 32bit workstation to check whether it works.
    Thanks
  • eryar
  • eryar
    Pipe and equpment models exported by ModelDataExchange
  • mine mine
    mine mine over 11 years ago
    Please Eryar can you share the link for the new improved version of EQUi/PIPE exporter?
    Thank you and Great Job!
  • Pedro Valadares
    Pedro Valadares over 11 years ago
    Hi !
    It does not seem to work under AVEVA Plant 12.1 SP2
    I edited pdms.bat as below
    set pdms_installed_dir=C:\AVEVA\Plant\PDMS12.1.SP2\
    call %pdms_installed_dir%\pdms
    When I run ModelDataExchange\pdms.bat, it shows the following message
    Warning: Failed to load addin assembly C:\AVEVA\Plant\PDMS12.1.SP2\ModelDataExchangeAddin.dll
    I checked the file above and it does exist.
