• Hi, pvaladares:
    There is no pdms.bat file in ModelDataExchange folder.
    There is a Run.bat file, only modify this file, and run PDMS by this file.
    In the Run.bat file, will set the environment variable for ModelDataExchange addin.
    Regards.
    [QUOTE=pvaladares;82409]Hi !
    It does not seem to work under AVEVA Plant 12.1 SP2
    I edited pdms.bat as below
    set pdms_installed_dir=C:\AVEVA\Plant\PDMS12.1.SP2\
    call %pdms_installed_dir%\pdms
    When I run ModelDataExchange\pdms.bat, it shows the following message
    Warning: Failed to load addin assembly C:\AVEVA\Plant\PDMS12.1.SP2\ModelDataExchangeAddin.dll
    I checked the file above and it does exist.
  • Hi, albycad,
    I will post the new version of ModelDataExchange addin in my blog soon.
    You can download it there.
    Thank you.
    [QUOTE=albycad;82403]Please Eryar can you share the link for the new improved version of EQUi/PIPE exporter?
    Thank you and Great Job!
  • Hi eryar !
    Yes, I meant 'run.bat' instead of 'pdms.bat'.
    I set the environment variables in the 'run.bat', and doubled checked adding 'echo %var%'.
    Environment variables are set and dll files are copied.
    Everything seems to be OK but PDMS still shows the message
    Not possible load one or more requests. Please check the LoaderExceptions for further information.
    Maybe it is related with the .NET Framework / Development tool used...
    [QUOTE=eryar;82471]Hi, pvaladares:
    Regards.
  • Hi pvaladares.
    Maybe the .Net Framework for ModelDataExchangeAddin is not match the version in the AVEVA Plant 12.1.
    I compiled the addin with .Net Framework 3.5 in AVEVA Plant 12.0.
    [QUOTE=pvaladares;82479]Hi eryar !
  • I publish the ModelDataExchange Addin V1.0 here: http://www.cppblog.com/eryar/archive/2013/09/11/203182.html
    You can download it and have a try. Enjoy!
    Functions:
    1. Export equipment models;
    2. Export piping models;
    Any feedback is welcome!
  • You are welcome!:teapot:
    [QUOTE=sopot;83422]Great Jobs!
    THX
  • 2014-03-20
    ModelDataExchangeAddin V1.1
    1. Skip null Catref of Nozzles;
    2. Skip zero dimension primitives shapes;
    Download ModelDataExchangeAddin: ModelDataExchangeAddin V1.1
  • Use Model Data Exchange Addin to export structure models for PDMS:
    Figure 1.1 Structure models in AVEVA PDMS
    Figure 1.2 Structure models exported by Model Data Exchange
    Figure 1.3 Put pipes, equipments, structures together
    Figure 1.4 Export pipes, equipments and structure models by Model Data Exchange
    Figure 1.5 Valves and Pumps
    Figure 1.6 Pipes and structures
  • Figure 1 Models in AnyCAD .Net
    Figure 2 Valves with Insulation
