General
General
Show Off Your Work! Piping Component Dimensions
  • Replies 36 replies
  • Views 142 views
Aurelio Hinampas
Aurelio Hinampas over 11 years ago
  • Aurelio Hinampas
  • Aurelio Hinampas
    https://aveva.dev-verintcommunity.com/cfs-file/__key/communityserver-discussions-components-files/1635/280683pcompDim.pmlfrm
  • Raul Perez May
    Raul Perez May over 11 years ago
    Excelent!!
  • Venkata Rao Peta
    Good work rhel.
  • Wouter
    Wouter over 11 years ago
    Thank you, very helpful tool.
  • Aurelio Hinampas
    Welcome, Woutr...
    Some additional fixed with the macro, please replace the method dimRemove with the code below: Purpose is not to overload the Aid Number array, it might cause to slow down your PC if the Array is not Cleared and contains too many items in the array when you Remove All Dimensions...
    define method .dimRemove( !action is string )
    if (!action.eq('ALL')) then
     do !i values !this.aidNum
      aid clear all $!
     enddo
     !this.aidNum.clear()
    else
     !ceRefe = !!ce
     branch
     handle any
      return error 1 '$!!error.text'
     endhandle
     !number = !!ce.string().substring(2).replace('/','').substring(6)
     !!ce = !ceRefe
     aid clear all $!
  • Tomas Veleman
    Tomas Veleman over 11 years ago
    Good job.
    By the way, this mentioned method work just with bran ... so i did small modification let we can use it on PIPE :
         aid clear all $!
       enddo
     else
       !ceRefe  = !!ce
       var !delaid coll all branch for ce
       do !dd values !delaid
        $!dd
        handle any
        endhandle
        !!ce  = !ceRefe
        aid clear all $!
  • Aurelio Hinampas
    Tomek, thanks for the comment. You can freely modify the macro. A little modification with the code below.
         aid clear all $!
       enddo
     else
       !ceRefe  = !!ce
        !number  = !dd.substring(2).replace('/','').substring(6)
        aid clear all $!
  • Aurelio Hinampas
    Tomek, I have modified the method dimRemove that will supports the type Branch, Pipe & etc...
    aid clear all $!
    enddo
    else
    !ceRefe = !!ce
    branch
    handle any
    -- Collect All Branch:
    var !branch collect all branch for ce
    if (!branch.size().eq(0)) then
    return
    endif
    golabel /skipBran
    endhandle
    !branch[1] = !!ce.string()
    label /skipBran
    do !bran values !branch
    !number = !bran.substring(2).replace('/','').substring(6)
    aid clear all $!
  • Tomas Veleman
    i did the same changes, but in different way :-)
