Beginners 3dconnexion SpaceMouse Wireless and E3D 2.1
  • Replies 13 replies
  • Subscribers 2 subscribers
  • Views 70 views
Abílio Fernando Coutinho Martins Ramos
Abílio Fernando Coutinho Martins Ramos over 9 years ago
Top Replies
  • Sébastien
    Sébastien over 4 years ago +1
    Hello, I have the same problem using 3Dconnexion Spacemouse with E3D. The thing for the rotation is that E3D needs a point of rotation, given by the position of your cursor on the screen (visualized…
  • Markku Ahonen
    Markku Ahonen over 4 years ago
    Is there any way to change the orbit point / rotation point? Rotation works fine if there is only one small object on the screen.
  • Sébastien
    Hello,
    The thing for the rotation is that E3D needs a point of rotation, given by the position of your cursor on the screen (visualized by the small pink pin).
    If the pin is on an object, the view will rotate around it.
    But if the pin is not on an object, it's pinned "somewhere" in the background and the rotation is not controlled.
    When using the Spacemouse, the pin is not defined (in my opinion) and that's a start for troubles to arrive :)
    So if it can help someone to find/design a solution so we can use 3D mouses in E3D, it will be great !!
    • Vote Up +1 Vote Down
  • David Andreas Goldvin
    David Andreas Goldvin over 3 years ago in reply to Corrado Galluzzi
    Hello, I'm new on the forum and was wondering if there is any change since then regarding 3Dconnexion Spacemouse.
