Beginners 3dconnexion SpaceMouse Wireless and E3D 2.1
  • Replies 13 replies
  • Subscribers 2 subscribers
  • Views 70 views
Abílio Fernando Coutinho Martins Ramos
Abílio Fernando Coutinho Martins Ramos over 9 years ago
Top Replies
  • Sébastien
    Sébastien over 4 years ago +1
    Hello, I have the same problem using 3Dconnexion Spacemouse with E3D. The thing for the rotation is that E3D needs a point of rotation, given by the position of your cursor on the screen (visualized…
  • Abílio Fernando Coutinho Martins Ramos
    Hi E3D Gurus,
    Does anyone know if the SpaceMouse from 3dconnexion works on E3D 2.1? Or any other mouse from 3dconnexion?
    Ragards,
    ARamos
    No one have tested?
    Abílio Fernando Coutinho Martins Ramos over 8 years ago
    Sweet :) can you imagine on E3D?
    http://www.3dconnexion.es/products/spacemouse/spacemouse-enterprise.html
    Corrado Galluzzi over 8 years ago
    Extract from the latest E3D2.1 Fix6 Release Letter:
    SpaceMouse Support
    This release introduces support for a 3D SpaceMouseRegistered(3Dconnexion) to enable navigation in the 3D View of the Model and Draw modules (the mouse may only be used for navigation purposes).
    Enjoy!!!
  • Mikael Piukkala
    Mikael Piukkala over 8 years ago
    Hi, I have been trying too use a Spacepilot fom 3Dconnexion in E3d 2.1.0.6 and i have som issues, it don´t stop moving around it just keep rotating or zoom. Does anyone else have these problems, and if you have solved them pleace share.
    Hi [COLOR=#417394]MikaelPiukkala,
    Does your problem with infinite zoom or rotation has been fixed?[/COLOR]
  • Klaudiusz
    Klaudiusz over 8 years ago
    Is there any update for the 3d connexion? It does not work correct.
  • Matts Nordman
    Matts Nordman over 8 years ago
    Klauzer, what 3D mouse are you using?
    Edit: No, there has not been any updates lately.
  • Klaudiusz
    I am using 3dconnexion spacenavigator.
  • Peter Gulyas
    Peter Gulyas over 7 years ago
    I am trying to use an older SpaceExplorer (USB id 046D/C627) with E3D, but I also experience the continuous rotation and zooming. Which is actually not infinite: I can slow it down with the SpaceExplorer. Actually all 6 axes work, but they work in a strange way: they just add or substract to an inertia (linear or rotational speed) instead of always resetting to zero. When the space mouse is idle, it just doesn't add anything to e.g. the rotation speed, instead of setting the whole speed to zero, as would be desired.
    However I experience the same behaviour without even installing the 3DxWare driver, by using only the stock Windows HID input device driver. I cannot either change any settings by using the 3DxWare's xml files. Based on this, my assumption is that Aveva E3D fails to connect to the installed 3DxWare drivers, that sit on top of the standard USB HID driver, rather it just connects to the not-properly-working base Windows driver.
