Hi Guru
As per title topic, how to auto calculate the number of pipe spools on aveva e3d or aveva marine?
example below is the total number of spools in one pipeline. what is I want to count spools of several pipelines?
Hi Guru
Using Pipe Fabrication tool you get PSPOOL database elements.
You can assign them a unique name/number (with autonaming rules eventually).
Thank Corrado. Do we have other way to do it? I mean any command line once I click the pipe I just put the command to query the quantiquanti. spool number instead of generate isometric drawing?
If you do not use Pipe Fabrication toolset or SPOOLER Module, spools are generated/numbered automatically by Isodraft "engine" when producing isometrics.
They depend on piping component SHOP attribute.
