Macros & Tools Weld Gap / Weld Spool - Report
  • Replies 31 replies
  • Subscribers 14 subscribers
  • Views 271 views
Aurelio Hinampas
Aurelio Hinampas over 4 years ago
Top Replies
  • Aurelio Hinampas
    Aurelio Hinampas over 4 years ago +1
    [QUOTE=fadzlijais;116697]thanks for sharing. anyhow the macro didn't capture allowance provided for field Weld. How did you assign the Field Weld allowance on the piping components?
  • Mohd Fadzli
    Mohd Fadzli over 4 years ago +1
    Field Weld assign for weld with SKEY WF and loose flange allowance in option file set as 150mm as default. Allowance attribute for weld will be set as 300mm for FFW with SKEY WF since as default the…
  • Sgar Saha
    Sgar Saha over 4 years ago
    Looking for some new report IN EXCEL including tube weld bend and all bran mem.
    PIPE NAME,PIPE SPEC, PIPE ISPEC, BRANCH NAME, BRANCH SPEC,BRAN ISPEC,BRANCH HREF , BRAN TREF,TYPE,NAME,SPEC OF SPREF, DTXR OF TYPE, PL DIR, CREF,ABORE,ANGLE,RADI,ATLE,LTLE,stext of atta.
  • Aurelio Hinampas
    https://aveva.dev-verintcommunity.com/cfs-file/__key/communityserver-discussions-components-files/1598/202591aphWeldGapReport.pmlmac
  • Mohd Fadzli
    thanks rhel for the macro.
  • Sgar Saha
    Due to higher length of data letter, some of last column data are not coming in standard report. There is any settings to get long report.
  • Aurelio Hinampas
    https://aveva.dev-verintcommunity.com/cfs-file/__key/communityserver-discussions-components-files/1598/202594aphPipingCompReport.pmlmac
  • Sgar Saha
    It's working. Could you please update the macro with different column headings name.
  • Aurelio Hinampas
    https://aveva.dev-verintcommunity.com/cfs-file/__key/communityserver-discussions-components-files/1598/202596aphPipingCompReport.pmlmac
  • Indrajeet jha
    Indrajeet jha over 4 years ago
    rhel,
    The macro you have formulated for Weld Gap is very useful.
    Is there any minimum requirement formula to calculate minimum length of Spool ?
    If yes we can add it to this macro and have a specific Spool Check column for adequacy of design.
    I have already modify it based on our requirement.
  • Aurelio Hinampas
    For Minimum Weld Gap, formula to calculate the Minimum Gap is shown below:
    SP = SQRT(D * t)
    where;
       SP = separation between two pressure containing welds
        D = pipe diameter
        t = wall thickness of the pipe
    Note: SP shall be a minimum of 50mm
  • Indrajeet jha
    (2,751)   Variable !NEXTWALLT does not exist In line 133 of Macro \\xxxxxxxxxxxx\aphWeldGapReport.pmlmac
               !reportDatas = !pipeName & '^' & !branName & '^' & !compRefe.name & '^' & !compRefe.type & '^' & !compRefe.lbore & '^' & !compWallt & '^' & !nextDbRefe.name & '^' & !nextDbRefe.type & '^' & !nextRefBore & '^' & !nextWallt & '^' & !nextWeldGap & '^' & !error
    Called from line 1 of Command/Form Callback Command
    Following error shows on end of branch, I have checked the connections and Wall thickness for the Components, all are correct. It is on particular one line only where branch ends with ATTA and Pipe Tail is connected to TEE.
