Macros & Tools Weld Gap / Weld Spool - Report
  • Replies 31 replies
  • Subscribers 14 subscribers
  • Views 271 views
Aurelio Hinampas
Aurelio Hinampas over 4 years ago
Top Replies
  • Aurelio Hinampas
    Aurelio Hinampas over 4 years ago +1
    [QUOTE=fadzlijais;116697]thanks for sharing. anyhow the macro didn't capture allowance provided for field Weld. How did you assign the Field Weld allowance on the piping components?
  • Mohd Fadzli
    Mohd Fadzli over 4 years ago +1
    Field Weld assign for weld with SKEY WF and loose flange allowance in option file set as 150mm as default. Allowance attribute for weld will be set as 300mm for FFW with SKEY WF since as default the…
  • Aurelio Hinampas
  • Sgar Saha
    Sgar Saha over 4 years ago
    Hello Team,
    Any idea how to take slope report of pipe.
  • Aurelio Hinampas
    [QUOTE=Sagr;116988]Hello Team,
    You can get report for BRAN attributes of HDIRECTION TDIRECTION SLOREFERENCE
  • Sgar Saha
  • Aurelio Hinampas
    https://aveva.dev-verintcommunity.com/cfs-file/__key/communityserver-discussions-components-files/1598/202604aphWeldGapReport.pmlmac
  • vishal ashokan
    vishal ashokan over 4 years ago
    Sir this macro i wont be able to use in e3d can plz update it for e3d.
    Thanks
  • Aurelio Hinampas
    For E3D version, just replace the following macro line code:
    using namespace 'Aveva.Pdms.Presentation'
    Replace with
    using namespace 'Aveva.Core.Presentation'
    • Vote Up -1 Vote Down
  • Sgar Saha
    Hello , I have noticed that on this macro if fitting to fitting gap is zero than we are not getting that in report. Could you please let me know how to get that also .
  • Aurelio Hinampas
    Just remove or comment out the IF condition for Zero length spool as shown below
    -- if (!prevWeldGap.nint().gt(0)) then
       -- Report Datas
       !reportDatas = !pipeName & '^' & !branName & '^' & !nextDbRefe.name & '^' & !nextDbRefe.type & '^' & !nextRefBore & '^' & !nextWallt & '^' & !compRefe.name & '^' & !compRefe.type & '^' & !compRefe.abore & '^' & !compWallt & '^' & !prevWeldGap
       -- Store data to array
       !weldGapData.append(!reportDatas)
    -- endif
    -- if (!nextWeldGap.nint().gt(0)) then
       -- Report Datas
       !reportDatas = !pipeName & '^' & !branName & '^' & !compRefe.name & '^' & !compRefe.type & '^' & !compRefe.lbore & '^' & !compWallt & '^' & !nextDbRefe.name & '^' & !nextDbRefe.type & '^' & !nextRefBore & '^' & !nextWallt & '^' & !nextWeldGap
    -- endif
  • vishal ashokan
    its is showing error (44,33) fnf:file not found
