• Dear friends,
    I have to extract attribute for naviswork file.I know how to extract it but in dump att form we have only CE option so that we can extrac only UPTO one site ,but i want export attribute for many sites so how can i club these sites for exporting single dump attribute file.
  • Dear me_hungry
    can u share that form if possible ,i know very  little abt PML
  • export all sites may help you.change your export script like this.
    PDMS Allows to output .rvm
    make a list all sites and use utilities-->export to .rvm.Further you can use it in navis.
  • For my purpose I modified 'dump att' that it is copied all selected elemets from form'export to rvm' list..
    [url=http://rusfolder.com/foto/view_foto/v0rsp2i9nii8/][/url]
  • [COLOR=#333333]Hi [/COLOR][COLOR=#417394]sandesh.boddewae ![/COLOR][COLOR=#696969][/COLOR][COLOR=#3E3E3E][/COLOR][COLOR=#333333]
    [/COLOR]
    [COLOR=#333333]Dear me_hungry[/COLOR]
    [COLOR=#333333]can u share that form if possible ,i know very little abt PML[/COLOR]
    [COLOR=#333333]
    Maybe later when I will combine it with form 'export to rvm'( make it one form). Now its not well [/COLOR]adapted[COLOR=#333333].[/COLOR]
  • Dear me_hungry,
    Kindly note that i am using pdms12.0 sp3
    as per your instruction i have changed the extensions of file and added to mentioned folders
    after that rumn the command pml rehash all
    & try to export ffrom utility ,but it is showing the old default form for rvm
    I am not getting the as shown in your attached form
    can you send the procedure to how to use it
    many many thanks
    regards
    sandesh
  • dear aslam,
    can you explain the procedure to use it
  • Der me_hungry,
    please go throgh snap attached
    i have not understood "it should work, after re-entering coz its not usual form!!"
    [ATTACH=CONFIG]6549[/ATTACH]
    $(H
    (c) Copyright  1995 to Current Year  AVEVA Solutions Limited
    Macro:   fexpmain
    Author:  mas
    -- Modified by Gisar 23:25 30.05.2013, ��� "�����������������"
    Macro Generic Type: Form Definitions
    $(D
    Top level export form
    Arguments:
    Global Arguments:
    Returns:
    $:debug$:
    $* Kill existing form definition
    kill _CDXEXPMAIN
    $* Define form
    setup form _CDXEXPMAIN at xr 0.2 yr 0.2
    title    |Export|
    init     |CALLIB IFNAME FEXPMAIN|
    iconti   |Export|
    revision | $$Revision: 1.11 $ |
    $* Bar Menu
       bar
          add |File| _FILE
       exit
    $* File menu
       menu _FILE
          add |Load|             |CALLXR XEXPMAIN LOAD|
          add |Load from...|     |CALLXR XEXPMAIN LOAD FROM|
          add |Save|             |CALLXR XEXPMAIN SAVE|
          add |Save as...|       |CALLXR XEXPMAIN SAVE AS|
       exit
    $* Export template filename
       para _NAM at x 0 y 0 text |Template file|
       para _FNAME at xmax+1 ymin width 58 lines 1
    $* Export filename
       frame _OFR |Output file| at xmin_NAM ymax
         text _ONAM width 30 scr 120 str
    $* Export binary/Text?
         rtoggle _FTEXT at xmax+2 ymin |text|   states |Off| |On|
         rtoggle _FBIN                 |binary| states |Off| |On|
       exit
    $* Character Encoding
       var !characterSetting PROJ CHARSET
       var !multiByte PROJ MBCHAR
       if (!characterSetting.lowcase() eq 'unset' AND !multiByte.lowcase() eq 'unset') then
         -- Must NOT be a foreign language project
       else
         -- Must be a foreign language project
         frame _ENC |Character encoding|
           rtoggle _EUC |EUC |   states |Off| |On|
           rtoggle _UTF |UTF-8 | states |Off| |On|
         exit
       endif
    $* Export filenote
       text _FIL |Filenote| at xmin_NAM ymax+0.1 tagwidth 7 width 64 scr 120 str
    $* Button to call up drawlist form, also used as title for drawlist
       para _DRW at xmin_NAM ymax+1 text |Include|
    $*   button _B3 |Drawlist...| at 0 6 call |CALLXR IDRWLIST|
       para _RUL  at x37 ymin   text |Exclude|
       path d
       path l
    $* Drawlist & Exclude list
       list _DLIST at x0 ymax+0.2               width 33 length 10
       list _EXCL  at xmax_DLIST+2 ymin call || width 33 length 10
    $*   list _RULE at xmax_DLIST+1 ymin call |CALLXR IRULELIST COL| wid 32 len 10
    $*   list _RULE at xmax_DLIST+1 ymin mult wid 25 len 10
    $* Add CE, Pick & Remove button for Export Add List
       button _ADD     |Add|  at xmin form-0 ymax call |CALLXR MDRWLIST ADD|
       opt    _IADDOPT ||     at xmax ymin        call | CALLXR IRULESEL CLASS| width 9
      $*   button _PICK | Pick | at xmax ymax_DLIST call |CALLXR MDRWLIST PICK|
       button _REM     |Rem|  at xmax ymin call |CALLXR MDRWLIST DEL|
       opt    _IREMOPT ||         at xmax ymin    call | CALLXR IRULESEL CLASS| width 9
    $* Add CE, Pick & Remove buttons for Export eXclude List
       button _ADDX    |Add| at xmin_EXCL ymin             call |CALLXR MEXLLIST ADD|
       opt    _XADDOPT ||  at xmax ymin       call | CALLXR IRULESEL CLASS| width 9
      $*   button _PICKX | Pick | at xmax_ADDX+1.5 ymax_DLIST call |CALLXR MEXLLIST PICK|
       button _REMX    |Rem| at xmax ymin        call |CALLXR MEXLLIST DEL|
       opt    _XREMOPT ||  at xmax ymin    call | CALLXR IRULESEL CLASS| width 9
    $* Button to call up representation levels for export
       button _B4 |Representation...| at xmin_NAM ymax+1 call || form _CDXEXPREP
    $* Add rule to list
    $*   button _B5 |Rules...| at xmin_EXCL ymin CALL || form _CDXRULESEL
    $* Button to call up Rule File Selection...
       button _RULEFILE |Rule Class...| at xmin_NAM ymax+0.2 call || form _CDXRULESEL2
       para   _CUSED    at xmax_B4 ymin width 60 lines 1
    $* Delete rule from list
    $*   button _B6 |Remove Rule| at xmin_B5 ymax+0.2 call |CALLXR MRULELIST DEL|
    $*   list _DRAW at xmin_B3 ymax+0.2 wid 20 len 10
       path r
    $* Button to begin export
       button _B1 |Export| at xmin_DLIST ymax+1 call |CALLXR MEXPMAIN|
     -- UNXP
    toggle .unsetatt tagwidth 36 'Export unset attributes'    at xmin_RULEFILE ymax_RULEFILE      tooltip '<��������>'
    toggle .tproj    tagwidth 36 'TProjects'                  at xmax.unsetatt ymin.unsetatt      tooltip '<��������>'
    button .applyatt  'Export Attributes'  anchor right + top at xmin.B1 ymax.B1    call |$m /D:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\intf\review\uexpatt.pmlmac|   width 10 lines 0.6  tooltip '<��������>'
    -- button .exptonwd  'NWD'           anchor right + top at xmin.applyatt ymax.applyatt   call |!this.<�����>()|   width 10 lines 0.6  tooltip '<��������>'
    button .stop    |STOP|         anchor r+b at xmax form -size
    !!CDXEXPMAIN.stop.background = 'Red'
    !!CDXEXPMAIN.stop.visible = false
    $* Cancel button
       button _B2 |Dismiss| at xmax form-size ymin call |CALLXR MCLOSEALL|
       var userdata _CDXEXPMAIN || 1
    $* End of form definition
    exit
    return $* >>>>>>>>>> End of Code FEXPMAIN <<<<<<<<<<
