[QUOTE=pverci;103187]Very good information grizzly83. Thank you.
The only thing i had to change in your code was the variable name for all collected componets
!COLL instead of !All
Maybe this could help the others, too
Serious necro post, but considering I implemented this just today per customer request i'll add...
Our script calls the collection COLL as well, so thanks pverci.
As for Grizzly83 - modifications worked well, i will note though that it requires branch elements to be named.
First run through I did identify several tubes that failed to map and the root was the owning branch was not named. The rvm export names of unnamed branches with reference to the named pipe, eg TUBE 1 of BRANCH 1 of PIPE /abc while the att gives the name of db name of the branch, eg TUBE 1 of =123/45678.
As long as you have a workflow/quality process which ensures all pipe/branch elements are named this worked as intended.
[QUOTE=me_hungry;77402]Hi sandesh.boddewae
ARE u sure that U renamed old file [COLOR=#333333]D:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\intf\review\fexpmain to [/COLOR][COLOR=#333333]D:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\intf\review\fexpmain.backup
and added my attached ([/COLOR][COLOR=#333333]D:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\intf\review\fexpmain[/COLOR][COLOR=#333333])
Also foget to say it should work, after re-entering coz its not usual form!!
Forget to say, that to export tubi also should choose 'Tproj'.[/COLOR]
Hello me_hungry! I have done everything You have mentioned and the first time after pml rehash in monitor and reentering in design I can see the form. But next time i enter design the messege I recevie is that from is not found! It's really strange. Got any advices?Thnks
Yeah I tried that but still no luck sometimes it opens the form but mostly gives me the error. Is this maybe regarding the SP5 we are using at the moment?
hahaha I don't know are You jokeing with me or are You serious :) We are using the 12.1.SP5 fix3. For me it's not mather of form I would like to be able to export all sites with everything within in one file, as we need the updated model everyday for the workshop.
Ahaha))
I thought you are talking about 12.0.5
Well, try to [COLOR=#333333]save my [/COLOR][COLOR=#333333]fexpmain[/COLOR][COLOR=#333333] file with [/COLOR][COLOR=#417394]encoding[/COLOR][COLOR=#333333] UTF-8(using notepad+ or other text editor)[/COLOR]
Is it possible to update only the modified and additional attributes in the .txt file? So for each run, it is not necessary the whole attributes are generated but only those that were added and modified? Thanks in advance for your help.
