• [QUOTE=me_hungry;77387]--I modified aready exist AVEVAs forms, hope they will not be angry:)
     I made some templates, quess it can help U.
    It has advantages relatively default:
    -possible to export att+rvm in one form
    -its possible to export tubi attributes
    ....................................Just dont forget to do what in the picture(tubi.png) make tubi separated!
    -its possible to export (owner\owner of owne) attributes inside 'member of bran'
    ..............................................................Just add needed(example [COLOR=#800080]!ATTL.append('para[1]')[/COLOR]) line after 161 line of macros uexpatt.pmlmac
    -added progress
    How to add:
    -Make backup for your macross --D:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\intf\review\fexpmain
    -Delete extension .txt(sory this forum doesnt support (.pmlmac)) on attachment files
    -Copy my attachmment to your directory--D:\AVEVA\Plant\PDMS12.0.SP6\PDMSUI\intf\review\
    Try and write your thinkin of it..
    how i can get the attribute DTXR of the individual Branch members example VALV, currently its showing the Attribute at Branch and Pipe Level.
  • What do U mean to 'get the att DTXR for BRAN MEM'. It should upload DTXR for all bran MEM (if it is NOT UNSET).
    Try to convert .att file to UTF8, if U have cyrillic values in DTXR...
  • Yes, I am looking for the DTXR attribute of branch mem
    I have already copied the content of .att file and pasted into a new document in worpad and saved it as .txt
    When I try to open the .rvm file pdms attributes are not shown at branch mem level.
    Only when I click a bran or a pipe it shows the pdms attributed tab in naviswork
  • iF I CHECK Q dtxr in PDMS it outputs the result correctly
  • Well I dont know, but macro that creates .att file, check the value of SPREF.
    U may also check in .att file, if macros outputs BRAN MEM attributes .
  • I checked the .att file and the Bran mem is showing the DTXR attribute
    now i need to know  what is the reason for naviswork not understanding it.
    NEW /GC-6"-F06-90AD/B1
                    NAME:=  /GC-6"-F06-90AD/B1
                    TYPE:=  BRAN
                    LOCK:=  false
                   OWNER:=  /GC-6"-F06-90AD
                    DESC:=  unset
                    FUNC:=  unset
                    PURP:=  unset
                    BUIL:=  false
                    SHOP:=  false
                    ISOH:=  false
                    HPOS:=  E 26845.896mm N 6687.597mm U 10077.435mm
                    TPOS:=  E 13213.1mm N 14200.343mm U 12769.68mm
                    HDIR:=  W 1 S
                    TDIR:=  W 89.6779 D
                    HREF:=  =0/0
                    TREF:=  =67139249/2072
                    LHEA:=  true
                    LTAI:=  true
                    HBOR:=  150mm
                    TBOR:=  150mm
                    HCON:=  CLOS
                    TCON:=  BWD
                    DETA:=  false
                    LSTR:=  false
                    LNTP:=  unset
                    EREC:=  0
                    TEMP:=  -100000degC
                    PRES:=  0pascal
                  TPRESS:=  0pascal
                    FLOW:=  unset
                    HSTU:=  /CC0NA1/TUBE/007
                    CCEN:=  0
                    CCLA:=  0
                    SAFC:=  0
                    MATR:=  =0/0
                    FLUR:=  =0/0
                    CASR:=  =0/0
                    PSPE:=  /CC0NA1
                    ISPE:=  =0/0
                    TSPE:=  =0/0
                    DUTY:=  unset
                    DSCO:=  unset
                    PTSP:=  unset
                    INSC:=  unset
                    SPLH:=  unset
                    HDMT:=  unset
                    HDMF:=  unset
                    TDMT:=  unset
                    TDMF:=  unset
                    LISS:=  false
                    WMAX:=  0
                    PMAX:=  0
                    PTNH:=  0
                    SMAX:=  0
                    JMAX:=  0
                    MTOH:=  unset
                    PTNB:=  unset
                    DRRF:=  =0/0
                    SPSP:=  unset
                    JNUM:=  unset
                    JOIP:=  unset
                    ORRF:=  =0/0
                  BENDMA:=  =0/0
                    INCO:=
                   PLANU:=  unset
                    BSTA:=  0
                    HWRF:=  =0/0
                    TWRF:=  =0/0
                    BRLO:=  0
                    RLST:=  unset
                   TSFBR:=  false
                  DELDSG:=  FALSE
                  MDSYSF:=  unset
                  INPRTR:=  =0/0
                  OUPRTR:=  =0/0
                  SLOREF:=  =0/0
             :MDSCOMMENT:=  unset
               :MDSDTYPE:=  unset
                :MDSTRUN:=  false
          END
          NEW TUBE 1 of BRANCH /GC-6"-F06-90AD/B1
                NAME:=  ileave tube of /GC-6"-F06-90AD/B1
                TYPE:=  TUBI
               OWNER:=  /GC-6"-F06-90AD/B1
                GRDE:=  0
                LBOR:=  150mm
                SPRE:=  /CC0NA1/TUBE/007
                ITLE:=  41.274mm
                ITPS:=  E 26825.262mm N 6687.237mm U 10077.435mm
                DTXR:=  PIPE SEAMLESS BE ASME B36.10
                MTXX:=  API 5L;GR.B;NACE MR0175;SCH120
             PARA[1]:=  150
              P1CONN:=  TUB
            NEW FLANGE 1 of BRANCH /GC-6"-F06-90AD/B1
                               NAME:=  =67147441/2441
                               TYPE:=  FLAN
                               LOCK:=  false
                                POS:=  E 26679.447mm N 6684.692mm U 10077.435mm
                                ORI:=  Y is N 1 W and Z is U
                               DESP:=  unset
                               BUIL:=  false
                               SHOP:=  true
                               ISOH:=  false
                               SPRE:=  /CC0NA1/FLAN/009
                               LSTU:=  /CC0NA1/TUBE/007
                               ARRI:=  2
                               LEAV:=  1
                               POSI:=  E 26679.447mm N 6684.692mm U 10077.435mm
                               ISPE:=  =0/0
                               TSPE:=  =0/0
                               LOOS:=  false
                               HEIG:=  0mm
                               CREF:=  =0/0
                              CSFBR:=  false
                              TSFBR:=  false
                              ASFBR:=  false
                              LSFBR:=  false
                               SPLN:=  unset
                               SPLT:=  unset
                               MTOR:=  unset
                               CMPX:=  unset
                               PTNO:=  0
                               PTNT:=  0
                               PTNB:=  unset
                               JNUM:=  unset
                               JOIP:=  unset
                               MTOC:=  unset
                               MTOT:=  unset
                               MTOX:=  unset
                               SPSP:=  unset
                               DPFN:=  unset
                             DPGRID:=  0
                             NWELDS:=  0
                               ALLO:=  0mm
                               ORRF:=  =0/0
                               INVF:=  unset
                               BSEL:=  unset
                               MATN:=  unset
                               RLOC:=  -1
                               RLIN:=  unset
                               RLEX:=  unset
                               HREL:=  true
                             SPKCHG:=  =0/0
                             DELDSG:=  FALSE
                             INPRTR:=  =0/0
                             OUPRTR:=  =0/0
                             NOMDIR:=
                        :MDSCOMMENT:=  unset
                            :MDSCP1:=  unset
                            :MDSCP2:=  unset
                            :MDSCP3:=  unset
                        :MDSVPRMMTO:=  true
                               APOS:=  E 26804.628mm N 6686.877mm U 10077.435mm
                               LPOS:=  E 26679.447mm N 6684.692mm U 10077.435mm
                               DTXR:=  FLANGE WN RTJ 600# ASME B16.5
                               MTXX:=  ASTM A105N NACE MR0175, SCH120
                       NAME OF OWNE:=  /GC-6"-F06-90AD/B1
               NAME OF OWNE OF OWNE:=  /GC-6"-F06-90AD
            END
  • Very good information grizzly83. Thank you.
    The only thing i had to change in your code was the variable name for all collected componets
    !COLL instead of !All
    Maybe this could help the others, too
