• if we want to represent a flanged end pipe from sizes 12"-48" and we need flanged end to appear in our isometric output as geometric representation is it possible to do it do we have this kind of library in our paragon module in E3D Please let me know.
  • WOW! Another breathless sentence anindya! ;-)
    I am not sure you can find anything like that in Aveva supplied ACP Project
    I think you need to create a FTUB Category and use FPFL Skey in its SDTE element
  • but in ftub also we donot have flanged ends likewise we use text as flanged end pipe and use plain end as geometry while extracting in isodraft which is a normal design practice in our 3dworld irrespective of the software or tool we use will aveva work on something like this or we have ftub as only element available because while extracting mto it will not be a pipe ; need to do tweeking for it to show as pipe
  • Sorry but I get lost reading your long sentences......
    Punctuaction is free of charge here and it helps you to be better understood ;-)
    Could you please post some pictures?
    I apologize but I am not sure I have understood your request.
    Thank you!
    Thank you!
  • Sorry for the inconvinience. I was trying to convey that in 3d engineering realm ; we don't actually go out of the way in creating flanged pipes if it is not a necessity. While taking Isodraft outputs in sdte we can mention as flanged pipes , most likely. In other words, as you had mentioned in your trailing reply that , I need to use  FTUB with flanged ends. It means i have to create geometry of scylinder for pipe and two scylinders on either end for a flange.  So, When I am taking Bill of Materials , then it will appear as a Ftub not a pipe which my goal. In order to achieve this should, I switch off the MTO or How do I approach this issue. Please do let me know mate.
